China Fume Extractor
astao228
#1 Сообщение astao228 » Ср янв 08, 2020 4:59 am
Product Overview
Pure-Air PA-700FSR-IQ 3D Printing Machine Fume Extractor has very good performance for air filtration for printing progress, it can adsorb ink smell and collect dust for 3D Printing progress. With DC 24V remote control socket to start and stop with printing machine.
PA-700FSR-IQ 3D printer air filter air flow is 700m³/h, blower capacity is 600W, air flow can be adjustable both by key switch and remote control, it has LCD display to show air pressure and air flow. It also has warning system to remind customer to replace filters once filters blocked. And it has the function that can work with printing machine synchronously.
PA-700FSR-IQ 3D Printer Dust Collector has below 4 layer filters to make sure the high air purification performance.
1) 1st layer is F5 Primary filter for remove big and heavy particles/smoke/dust (>=5Micron)
2) 2nd layer is F8 medium efficiency filter for remove big particles/smoke/dust (>=1Mircron).
3) 3rd layer is H13 class HEPA filter to remove small particles (>=0.01Mircron) and smoke.
4) 4th layer is Activated carbon filter to adsorb smells and toxic gas.
Product Specification
3D Printing Machine Fume Extractor Equipment Data
ItemTechnical DataRemark
Fume & dust inlet¢75mm / ¢100mmSingle fume inlets, include 1pc black PU tube
Fresh air outlet¢75mm / ¢100mmShutter holes
Machine weight110KG (N.W.)Machine with all elements
Dimension692*950*810mmMachine size
Package dimension950*950*1060mmPacked by plywood crate
3D Printing Machine Fume Extractor Blower Technical Data
Running periodmore than 30,000hOne year guarantee
Max. air flow700m³/hElectronic speed control
Input capacity600WLow capacity
Air pressure3800paHigh pressure
Running sound≤65dBALow sound volume
Input power110V/220V, 50Hz/60HzInternational standard
3D Printing Machine Fume Extractor Filter Elements Data
PA-700FSR-IQ 1st layer filterF5 Class Filter PadCotton filter pad.
PA-700FSR-IQ 2nd layer filterF8 Class deep pleat filterFilter can remove 90% of all particles above1 microns
PA-700FSR-IQ 3rd layer filterH13 Class HEPA filterFilter can remove 99.997% of all particles above 0.3 microns and 95% down to 0.01 micron.
PA-700FSR-IQ 4th layer filterGas FilterChemical molecular,Oxidant & Active carbon adsorb noxious gas.
Average filtration rate≥99.7%It will be a little fluctuation according to different materials.
Product Features
PA-700FSR-IQ 3D Printing fume extraction system air flow is 700m³/h, with LCD display and remote control to show air flow and air pressure, air flow can be adjustable, Assemble brushless blower with more than 30000 running hours. With filter block alarm function to remind customer to replace filters once they are blocked. With Low noise, bigger suck power, high filtration performance,nice quality, easily move.
Function of the Machine
A. Application: Printing, 3D Printing, Laser marking, engraving, cutting, coding, etc.
B. Working principle: the high performance brushless fan in the machine generates negative pressure, sucks the smoke and exhaust gas into the filter, and carries our indoor discharge after the multi-stage filter elements such as medium filter, HEPA filter and gas filter are effectively purified.
C. Features and advantages:
(1). Low noise;
(2). Low power consumption maintenance-free brushless fan with a service life of more than 30000 hours;
(3). High capacity filter;
(4). Filtration efficiency up to 99.99% @ 0.3um;
(5). Filter blocking alarm;
(6). Easy maintenance and replacement of filter elements.
Product Applications
PA-700FSR-IQ printing fume filter is suitable for air purification for printing process, 3D Printing, etc.
After-sales
3D Printing Machine Filter with 1 year guarantee not including spare filters;
Pure-Air Product pass CE Certification.
Product Pictures
Product CertificatesChina Fume Extractor
website:http://www.fume-filter.com/fume-extractor/
