роман писал(а):Откуда вообще пошол этот идиотизм
Nissan писал(а):Changing CVT Fluid
1. Warm up CVT fluid by driving the vehicle for 10 minutes.
2. Drain CVT fluid from radiator cooler hose (return side) and refill
with new CVT fluid at charging pipe with the engine running at
idle speed.
3. Refill until new CVT fluid comes out from radiator cooler hose
(return side).
About 30 to 50% extra fluid will be required for this procedure.
Fluid capacity
Hyper CVT: Approx. 8.1! (7-1/8 lmp qt)
Drain plug:
: 23 - 27 N·m (2.4 - 2.8 kg-m, 18 - 20 ft-lb)
CAUTION:
Use genuine NISSAN CVT fluid (NS-1) or exact equivalent.
ММС писал(а):A/T FLUID REPLACEMENT
If you have a A/T fluid changer, use this changer to replace the
A/T fluid. If you do not have a A/T fluid changer, replace the A/T
fluid by the following procedure.
1. Disconnect the hose shown in the illustration which
connects the transaxle and the oil cooler (inside the
radiator). Place a container under the hose to collect the
discharge.
CAUTION
The engine should be stopped within one minute after it is
started. If the A/T fluid has all drained out before then, the
engine should be stopped at that point.
Discharge volume: Approximately 3.5 dm3 (3.7 quarts)
2. Start the engine and let the A/T fluid drain out.
Running conditions: "N" range with engine idling
3. Remove the drain plug from the bottom of the transaxle case
to drain the A/T fluid.
Discharge volume: Approximately 2.0 dm3 (2.1 quarts)
4. Install the drain plug with a new gasket, and tighten it to the
specified torque.
Tightening torque: 32 ± 2 N⋅m (24 ± 1 ft-lb)
CAUTION
Stop pouring if the full volume of A/T fluid cannot be
poured in.
5. Pour new A/T fluid in through the oil filter tube.
Adding volume: Approximately 5.5 dm3 (5.8 quarts)
6. Repeat the procedure in Step 2. (to pump out the rest of the
contaminated A/T fluid)
7. Pour the new A/T fluid in through the oil filler tube.
Adding volume: Approximately 3.5 dm3 (3.7 quarts)
NOTE: Check the A/T fluid for contamination or burnt smell.
If fluid is still contaminated or burnt, repeat Steps 6 and 7
before proceeding to Step 8.
8. Reconnect the hose which was disconnected in step 1
above, and firmly replace the dipstick.
9. Start the engine and run it at idle for one to two minutes.
10.Move the selector lever through all positions, and then move
it to the "N" position.
11.Check that the A/T fluid level is at the "COLD" mark on the
dipstick. If the level is lower than this, pour in more A/T fluid.
12.Drive the vehicle until the A/T fluid temperature rises to the
normal temperature [70 − 80°C (158 − 176°F)], and then
check the A/T fluid level again. The A/T fluid level must be at
the "HOT" mark.
NOTE: The A/T fluid temperature is measured with scan tool
(MUT-II).
NOTE: The "COLD" level is for reference only; the "HOT"
level should be regarded as the standard level.
NOTE: If it takes some amount of time until the A/T fluid
reaches its normal operating temperature [70 − 80°C (158 -
176°F)], check the A/T fluid level by referring to the left
diagram.
13.Firmly insert the dipstick into the oil filler tube.
whitecat0601 писал(а):нужно ли что то в данный момент делать с коробкой или она работает штатно? Уровень атф в норме, цвет запах ОК.
Кто хоть раз делал AXOD -такую замену будет делать только под страхом растрелаarsas писал(а):роман писал(а):против слива масла из коробки без пополнения коробки маслом.
В Мицубишевском мануале рекомендуют менять именно так-выше читайте.Одно ограничение-не держать двигло заведенным более одной минуты\заглушить, когд АТФ кончается.
роман писал(а):arsas писал(а):роман писал(а):Так менять масло.как по мне путь к ремонту коробки за свой счёт.
