нужен мануал на шевроле блайзер TH 400 весь инет перерыл толком нет ничего
http://www.nastyz28.com/chevy-transmiss ... cation.php
THM400 - The THM400 was GM's Heavy-duty 3 speed transmission used from 1964 to 1990. Used on large displacement, high torque engines and engines with towing packages. Generally found in Chevy & GM trucks, cadilacs and large displacement engined, full size GM rear wheel drive cars.
3L80 - The 3L80 is a renamed THM400, used in the early 1990's. The 3L80HD would be the THM475 (heavy duty unit).
4L80 - An overdrive model of the THM400. The 4L80E would be the "electronic" model.
Мануал из ATSG
http://www.scribd.com/doc/49530515/th-400
Мануал из ATSG
