Stone Coated Metal Roof Tile
Helengriffin21
#1 Сообщение Helengriffin21 » Вт фев 11, 2020 5:50 am
Colorful stone coated roof tile is a new high-tech roofing material, which uses aluminized and zinc-plated steel plate with excellent anticorrosive performance as its base plate, acrylic resin with strong weather resistance as its binder and natural sand as its surface layer. Because of its beauty, lightness, durability and environmental protection, it has become the mainstream product of international roofing materials in recent years, and is used in domestic high-grade buildings.
The colorful stone coated roof tile has weatherability, moisture resistance, salt spray resistance, impact resistance, acid resistance, alkali resistance, heat resistance and non-combustibility. The product is based on aluminized and galvanized steel sheet, and has multi-layer protective film treatment. It can withstand severe cold, hail, storm, snow, and extreme heat, earthquake and other adverse weather and natural disasters. It will not crack, aging, fire, wind, and has a long service life.
It can be used for wooden roof truss, steel frame, all-steel grid, concrete roof. Because of its flexibility and cutting characteristics, it is suitable for all kinds of buildings. It can also be safely constructed for roofs with slopes of (12-90 degrees), especially for "flat slope and roof renovation" projects. At the same time, it can replace the original clay tile, cement tile, color steel plate, glass fiber asphalt tile, slate tile and so on. At the same time, the original roof can be directly constructed without having to be demolished. Because of its large surface area, light weight, flexibility and cutting, the metal tile is firmly connected and fixed by its unique buckling design, structure and horizontal nailing method. This kind of dry construction is simple, fast and material-saving.
FAQ锛?
01.I Am Caring About the Environment. Is It Retractable If We Install Wanael Metal Roof Tiles?
Yes, Wanael stone coated steel roof tiles are produced with the latest technology, which is environment friendly. It is convenient to take off and re-install. Over 80% of stone coated steel roof tiles can be recycled. Other roof materials are non-recyclable.
02. Are Stone Coated Metal Roofs Noisy When It Is Raining?
No, the stone coated surface deaden the sound of the rain and even hail.
03.Does the Color fade? Any Corrosion?
NO. Wanael metal roofing tile are using high quality raw materials, and as well as the top international advanced production technology to ensure the durability and seismic resistance of the products.Stone Coated Metal Roof Tile
website:http://www.yahongrooftile.com/stone-coated-metal-roof-tile/
Сейчас этот форум просматривают: Yandex и 7 гостей
