Re: Форумчане, выручайте.
Братск 38 писал(а):
Братск 38 писал(а):
ZAP писал(а):Нормально сделанная коробка хорошо поедет и на Лукойле))
В ниссановские и митсу варики лью NS-2.
Слышал, что есть аналог красного цвета, но сам не практикую.
Аналог красного цвета - декстрон 3
В варик тоже залью NS-2 . Просто на семинаре , у иностранца спросили , что они заливают . Сказал что Dexron III , а NS-2 у них нет .
Эти иностранцы Вас обманули!
arsas писал(а):Также извиняюсь за оффтоп.
http://www.oilspecifications.org/general_motors_gm.php
General Motors Oil Specifications
Automatic Transmission Fluids
Dexron Type A, Suffix A
Specification introduced in 1957. It requires the oil to meet certain limits regarding its kinematic viscosity.
Dexron IID
General Motors Dexron®-IID Specification. ATF issued in 1975. Contained ATF cooler corrosion requirements not listed in Dexron® - II.
Dexron IIE
General Motors Specification Dexron®-IIE. ATF issued in 1991 requiring improved low temperature performance compared to Dexron®-IID, 20 000 cP at minus 40 °C.
Dexron IIIF
GM specification for Automatic transmission oil introduced in 1994. Successor of Dexron IID and IIE.
Dexron IIIG
Successor of Dexron III(F) automatic transmission fluid. This has the same low temperature characteristics as Dexron IIE, but with modifications to anti-oxidancy and friction material. Introduced in 1997.
Dexron IIIH
Dexron III licence H was introduced in June 2003 to replace the Dexron III G fluid. It has an oxidatively stable base oil (group 2 or group 3). Oils according to this specification have longer maintenance of friction properties and anti-shrudder properties, better foam control and a longer fluid life.
Dexron VI
Specification introduced in 2005 to replace Dexron IIIH. This specification requires better stay-in-grade properties, oxidative stability and anti-foam characteristics. Oils meeting this specification can be used with extended drain intervals and are energy conserving.
Неоднократно слышал утверждение, что GM в настоящее время не поддерживает спецификации Dexron III, поэтому появилось много производителей типа http://autohim116.ru/catalog/avtomasla- ... -po-4.html 150 рублей за литр :o
Именно эти слухи меня и ввели в заблуждение.
