Здравствуйте.
Подскажите, какое линейное давление должно быть в акпп 4HP20?
АКПП 4HP20 ПЕЖО607
between 15.5 and 18 bar in 1st and reverse gears,
• between 5.5 and 8.8 bar in the other gears.
The ECU imposes a line pressure of 15.5 - 18 bar in the following cases
if: • a gear is being changed,
• downgraded mode is operational (transmission is locked in 3rd
hydraulic)
In stabilised mode, the ECU can switch the pressure from one value to
another depending on the turbine torque:
• 5.5 - 8.8 bar for turbine torque ≤ 230 mN,
• 15.5 - 18 bar for turbine torque > 230 mN.
hydraulic)
С уважением, Евгений!
